RajaDaja's avatar
RajaDaja
Luminary
Mar 02, 2025
Randomly disconnects and will not reboot until unplugged
Hello,
On a handful of occasions, usually during late night, my modem crashes and will not reboot until it's unplugged. When this happens I  also disconnect the router. After the modem quickly comes back online, I plug back in my router and everything is fine.
My internet provider is Xfinity, I have Netgear Orbi 973. My internet tier is x2 gigabit down & 300mb up. Speed test is what it should be.
See Modem log is attached;
Cable Connection
Cancel Apply
Cable Diagnostic
Status:   Good
Action:
Your setup looks fine. If you can't access the internet, make sure you properly activated the modem. If modem has been activated and you still can't access the internet, contact your service provider for troubleshooting help.
If you can access the internet but has other internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
CM Status:
Downstream Status:
Upstream Status:
 Refresh Save Cable Diagnostic Info
Advanced Information
Frequency Start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel399000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDIPv6 only
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM2564399000000 Hz4.4 dBmV44.7 dB00
2LockedQAM2561381000000 Hz4.8 dBmV44.8 dB00
3LockedQAM2562387000000 Hz4.6 dBmV44.8 dB00
4LockedQAM2563393000000 Hz4.4 dBmV44.6 dB00
5LockedQAM2565405000000 Hz4.2 dBmV44.6 dB00
6LockedQAM2566411000000 Hz4.1 dBmV44.2 dB00
7LockedQAM2567417000000 Hz4.1 dBmV44.5 dB00
8LockedQAM2568423000000 Hz3.9 dBmV44.4 dB00
9LockedQAM2569429000000 Hz3.9 dBmV44.4 dB00
10LockedQAM25610435000000 Hz3.9 dBmV44.5 dB00
11LockedQAM25611441000000 Hz3.6 dBmV44.3 dB00
12LockedQAM25612447000000 Hz3.8 dBmV44.3 dB00
13LockedQAM25613453000000 Hz3.8 dBmV44.3 dB00
14LockedQAM25614459000000 Hz3.5 dBmV44.1 dB00
15LockedQAM25615465000000 Hz3.5 dBmV44.1 dB00
16LockedQAM25616471000000 Hz3.7 dBmV44.2 dB00
17LockedQAM25617477000000 Hz3.4 dBmV44.0 dB00
18LockedQAM25618483000000 Hz3.2 dBmV43.9 dB00
19LockedQAM25619489000000 Hz3.3 dBmV43.9 dB00
20LockedQAM25620495000000 Hz3.1 dBmV43.8 dB00
21LockedQAM25621501000000 Hz2.8 dBmV43.7 dB00
22LockedQAM25622507000000 Hz2.7 dBmV43.5 dB00
23LockedQAM25623513000000 Hz2.8 dBmV43.6 dB00
24LockedQAM25624519000000 Hz2.5 dBmV43.5 dB00
25LockedQAM25625525000000 Hz2.5 dBmV43.5 dB00
26LockedQAM25626531000000 Hz2.4 dBmV43.4 dB00
27LockedQAM25627537000000 Hz2.2 dBmV43.2 dB00
28LockedQAM25628543000000 Hz2.1 dBmV43.2 dB00
29LockedQAM25629549000000 Hz2.1 dBmV43.1 dB00
30LockedQAM25630555000000 Hz2.0 dBmV43.0 dB00
31LockedQAM25631561000000 Hz2.2 dBmV43.1 dB00
32LockedQAM25632567000000 Hz2.3 dBmV43.1 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA185120 Ksym/sec22800000 Hz38.3 dBmV
2LockedATDMA175120 Ksym/sec16400000 Hz37.8 dBmV
3LockedATDMA195120 Ksym/sec29200000 Hz38.8 dBmV
4LockedATDMA205120 Ksym/sec35600000 Hz39.3 dBmV
5Not LockedUnknown0000.0 dBmV
6Not LockedUnknown0000.0 dBmV
7Not LockedUnknown0000.0 dBmV
8Not LockedUnknown0000.0 dBmV
Downstream OFDM Channels
ChannelLock StatusProfile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,2 ,3193722000000 Hz1.38 dBmV41.7 dB388 ~ 37074392784374217075336
2Locked0 ,1 ,2 ,3194957000000 Hz-2.82 dBmV39.0 dB148 ~ 39474449481864349436840
Upstream OFDMA Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
1Locked12 ,134336200000 Hz35.5 dBmV
2Not Locked000 Hz0 dBmV
Extended Upstream Transmit Power
  • FURRYe38's avatar
    Power looks ok.
    Please post the Event Logs as well.
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    • RajaDaja's avatar
      RajaDaja
      Luminary
      I cleared the log, when the disconnect happens I’ll post the event log. Thanks
