CBC0513
Dec 14, 2022Aspirant
RAX80 won't connect to CM2000
My ISP has updated their service from Docsis 3.0 to Docsis 3.1. To take advantage of this (and because I'm being charged more for it), I replaced my existing Netgear modem, which I've been using very...
- Dec 25, 2022Update ... Have set up the router as a new device. Almost all hurdles now cleared (WiFi working, as is separate AP). Two directly connected laptop issues to overcome, but I'd call this 'solved " now.
CBC0513
Dec 25, 2022Aspirant
Changed 80 from AP to router, immediately lost connection to the device when the update completed. Swapped out the modem to the new 2000, which connected successfully to my ISP.
No internet through the router when connected to the modem via Cat6 cable, and no ability to connect to the interface either via WiFi or LAN cable.
Rolled back to previous modem, and now am in the same position as with the new modem (no WiFi, no ability to connect to the interface to even toggle back to AP mode from router mode). This was what I was worried about ...
CBC0513
