thekid1751
Aug 12, 2016Aspirant
C3700 Drops Connection to Devices
I'm having an issue with my NetGear C3700. I've been using it for about 6 months with no issues. This past month, I've noticed it randomly drops connections to all wifi decises it's connected to....
mybudfrogs
Nov 25, 2016Aspirant
I have been having the same issue. I just did all the settings in the link above but I have little faith in that. I bought a n600 router for the speed but it seems to me that reducing the speed to just get the wifi to work is BS considering I bought it for the speed in the first place. Either give us a firmware up date that fixes the issues.
I am the only user on the system. One cell phone connected along with a laptop. My xbox is hardwire connected to the router.
What is strange is if the 5ghz stops working I can switch to the 2.4ghz. Then when it stops I can then switch to the other. It is getting hung up on something. I don't know what but I live in an isolated area so I have no channel interference to worry about.
one2admyr
Mar 06, 2017Aspirant
My continues to do the same. Customer support won't help unless you pay for it which costs more than the router itself. I will see if anyone can help me or if I can figure out a solution soon. Or next week I will go buy a new router, for sure not a netgear!!!
