SRM1992's avatar
SRM1992
Follower
Oct 01, 2026
CAX30 Xfinity Wireless Speed ~200mbps
I have an Xfinity 1gb wireless plan, getting a little over 900mbps over wired connection, my wireless connections are getting between 200mbps - at best 600mbps but mostly around the 200-400mbps. I've...
  • plemans's avatar
    Oct 02, 2026
    The reason they say it "isn't compabile" is that their 1 gig tier provisions at 1.2 gigs. So technically, it can't hit the full speed of the tier. But it'll hit 1 gig speeds no problems. Its just not multigig. So don't worry about it.
    In terms of speeds, 5ghz speeds decrease quickly with distance. As StephenB​ says, you're only going to get around that 600mbps out of 5ghz max. Which your post indicates you're hitting, With distance, obstructions, interference, those speeeds will drop off quickly. But 200mbps is still proficient with anything you're doing. Streaming 4k only takes 25-50mbps. So unless you're moving massive datasets/backups/etc regularly, you won't really notice the difference unless you're speedtesting.
