brief-actuator
Dec 11, 2025Tutor
CAX80 v5.1.1.8 Firewall Blocking HTTPS API Traffic - DMZ Confirmed
Hi all, I'm experiencing a firewall bug on my CAX80 (firmware v5.1.1.8) that's blocking HTTPS API calls to legitimate services (specifically api.anthropic.com for Claude AI/Claude Code). Symp...
- Dec 11, 2025
What region are you located?
Who is your ISP?
Is SIP ALG enabled on the modem?
Something to contact NG about.
Something to contact NG support about.
Look up what ports are used by your API traffic and input that in to Port Forwarding or Port Triggering configuration. If you try this, be sure to disable uPnP before hand.
brief-actuator
Dec 13, 2025Tutor
StephenB port forwarding with UPnP disabled seems to be working so far! Thanks so much for your quick help :)
Dec 14, 2025Guru - Experienced User
brief-actuator wrote:port forwarding with UPnP disabled seems to be working so far!
Great!
You might do a bit more testing, to make sure both ports need to be forwarded.
