erchicago85
Apr 10, 2024Aspirant
Re: CAX80 with Xfinity wifi texting failing
I'm also having the same issue with my CAX80 (see thread with the same topic) where the OP marked the solution as using a custom firmware of version 2.1.5.2. Picture texts over wifi aren't going through and am also having issues uploading files.
Has anyone else applied this fix or have a copy of the modified firmware?
Other user posted they contacted NG support and got it from them.
Has anyone else applied this fix or have a copy of the modified firmware?- erchicago85AspirantNetgear support insists there is no beta or custom firmware for the cax80. They had me change my DNS which didn't help.
Netgear, can you connect me to L2 support?- FURRYe38Guru - Experienced User
Contact NG support.
