jgnoonan
Dec 03, 2017Star
CM1000 Xfinity issues
I am quite frustrated at this point. I had a CM600 modem to support Comcast's Extreme 150 service. I've had it for a few years and was consistently getting 160 to 170mbps speed from it. About thre...
- Mar 12, 2018
Well it is finally fixed. The tech showed up today and I showed him the two frequencies that were having the problem. He checked outside, and then at the tap. He came into the house and said he needed to call a bucket truck in to fix it. I got a recorded call from Comcast that they were working to fix the issue. I got a second call an hour later that the issue was fixed. I ran a speed test and got a consistent 160mbps (yay!). I used the reset button on the modem and let it re-provision. All the signal/noise and power levels were good and there were no uncorrectable codewords. They didn't tell me what they fixed, but at long last, it is fixed.
BigQuark
Dec 22, 2017Guide
Hi, Can you post your Basic modem signal page and also under the Avanced Tab can youpost the Event Log page? Thanks!
jgnoonan
Dec 22, 2017Star
BigQuark Here is what I have for now. I would need to reconnect the modem and reprovision it and then put the comcast one back on and then reprovision that. First, here is confirmation of the version:
| Firmware Version V3.01.04 |
Here is the log. I will connect the modem later tonight when no one will be using the Internet.
- JonMJones10Dec 23, 2017Aspirant
I think I'm having the same issue! It's driving me bonkers. Here is what I posted on the Xfinity forums:
Hardware Info:
Hardware Version 2.02 Firmware Version V3.01.04 CM certificate Installed Here is the event log of the past 24 hours:
2017-12-23, 08:40:56
Warning (5)
REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx:xx:xx:xx:xx:10;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Time Not Established
Notice (6)
Honoring MDD; IP provisioning mode = IPv6
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=xx:xx:xx:xx:xx:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Critical (3)
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xx:xx:xx:xx:xx:10;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Critical (3)
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:10;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Critical (3)
2017-12-22, 17:53:40
Critical (3)
Resetting the cable modem due to docsDevResetNow
2017-12-22, 17:49:50
Critical (3)
Critical (3)
2017-12-22, 14:14:06
Critical (3)
2017-12-22, 14:11:15
Critical (3)
2017-12-22, 14:07:01
Critical (3)
REG RSP not received;CM-MAC=xx:xx:xx:xx:xx:10;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Critical (3)
2017-12-22, 13:23:26
Critical (3)
Critical (3)
2017-12-22, 07:11:59
Critical (3)
Critical (3)
No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:10;CMTS-MAC=xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Note: I removed the MAC addresses, but the CM-MAC and CMTS-MAC do not match.Latest Log after a factory reset on the modem:
2017-12-23, 09:01:46
Critical (3)
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
2017-12-23, 09:00:19
Notice (6)
CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: E; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Warning (5)
Unicast DSID PSN startup error
2017-12-23, 08:59:49
Warning (5)
REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Notice (6)
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=xx:xx:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Critical (3)
No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Critical (3)
Here are my current connection stats:
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency <tabindex=-1>Startup Procedure
Procedure Status Comment Acquire Downstream Channel 729000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv6 only <tabindex=-1>Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 21 729000000 Hz 6.2 dBmV 40.3 dB 48754675 0 0 2 Locked QAM256 1 609000000 Hz 8.1 dBmV 41.0 dB 47253420 0 0 3 Locked QAM256 2 615000000 Hz 7.7 dBmV 40.9 dB 47261941 0 0 4 Locked QAM256 3 621000000 Hz 7.9 dBmV 41.0 dB 47271046 0 0 5 Locked QAM256 4 627000000 Hz 7.4 dBmV 40.9 dB 47280141 0 0 6 Locked QAM256 5 633000000 Hz 7.4 dBmV 40.6 dB 47285916 0 0 7 Locked QAM256 6 639000000 Hz 7.2 dBmV 40.7 dB 47299161 0 0 8 Locked QAM256 7 645000000 Hz 7.1 dBmV 40.6 dB 47307951 0 0 9 Locked QAM256 8 651000000 Hz 6.9 dBmV 40.5 dB 47317712 0 0 10 Locked QAM256 9 657000000 Hz 6.9 dBmV 40.5 dB 47326996 0 0 11 Locked QAM256 10 663000000 Hz 6.9 dBmV 40.4 dB 47336669 0 0 12 Locked QAM256 11 669000000 Hz 7.0 dBmV 40.6 dB 47345598 0 0 13 Locked QAM256 12 675000000 Hz 7.1 dBmV 40.1 dB 47355716 0 0 14 Locked QAM256 13 681000000 Hz 6.9 dBmV 40.3 dB 47363949 0 0 15 Locked QAM256 14 687000000 Hz 7.2 dBmV 40.6 dB 47373438 0 0 16 Locked QAM256 15 693000000 Hz 6.9 dBmV 40.2 dB 47382707 0 0 17 Locked QAM256 16 699000000 Hz 6.8 dBmV 40.2 dB 47380079 0 0 18 Locked QAM256 17 705000000 Hz 6.7 dBmV 40.5 dB 47410399 0 0 19 Locked QAM256 18 711000000 Hz 6.4 dBmV 40.4 dB 47419980 0 0 20 Locked QAM256 19 717000000 Hz 6.2 dBmV 40.3 dB 47428801 0 0 21 Locked QAM256 20 723000000 Hz 5.9 dBmV 40.3 dB 47430581 0 0 22 Locked QAM256 22 735000000 Hz 5.5 dBmV 40.2 dB 47438250 0 0 23 Locked QAM256 23 741000000 Hz 5.9 dBmV 40.2 dB 47444370 0 0 24 Locked QAM256 24 747000000 Hz 5.3 dBmV 40.1 dB 47449904 0 0 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 <tabindex=-1>Upstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 35800000 Hz 49.5 dBmV 2 Locked ATDMA 2 29400000 Hz 50.0 dBmV 3 Locked ATDMA 3 23000000 Hz 50.0 dBmV 4 Not Locked Unknown 0 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV <tabindex=-1>Downstream OFDM Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Not Locked Unknown 0 0 Hz 0 dBmV 0 dB 0 ~ 0 0 0 0 2 Not Locked Unknown 0 0 Hz 0 dBmV 0 dB 0 ~ 0 0 0 0 <tabindex=-1>Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked Unknown 0 0 Hz 0 dBmV 2 Not Locked Unknown 0 0 Hz 0 dBmV Current System Time: Sat Dec 23 09:17:13 2017
- jgnoonanDec 23, 2017Star
BigQuark OK. I finally got the modem reactivated which took more time that I thought. First, here is the link to the speed test I did. I have 150mbps service and with the Xfinity gateway I was getting a very solid 175mbps. With the CM1000, I'm getting about 80mbps.
http://speedtest.xfinity.com/results/JBJNMFPLV2Q17ZE
I am going to keep the CM1000 connected until we can resolve the issue. Here is the data you requested;
Procedure Status Comment Acquire Downstream Channel 441000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv6 only <tabindex=-1>Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 4 441000000 Hz 3.1 dBmV 38.0 dB 32255290 8 0 2 Locked QAM256 1 423000000 Hz 3.7 dBmV 38.4 dB 30759191 16 0 3 Locked QAM256 2 429000000 Hz 3.8 dBmV 38.6 dB 30769845 9 0 4 Locked QAM256 3 435000000 Hz 3.6 dBmV 38.4 dB 30778760 10 0 5 Locked QAM256 5 453000000 Hz 2.3 dBmV 37.5 dB 30788847 25 0 6 Locked QAM256 6 459000000 Hz 1.9 dBmV 37.1 dB 30797731 29 0 7 Locked QAM256 7 465000000 Hz 1.7 dBmV 36.6 dB 30807102 16 0 8 Locked QAM256 8 471000000 Hz 1.3 dBmV 36.1 dB 30816615 27 0 9 Locked QAM256 9 477000000 Hz 1.1 dBmV 35.8 dB 30825593 29 0 10 Locked QAM256 10 483000000 Hz 0.7 dBmV 35.6 dB 30834441 41 0 11 Locked QAM256 11 489000000 Hz 0.6 dBmV 35.9 dB 30844020 28 0 12 Locked QAM256 12 495000000 Hz 0.8 dBmV 36.2 dB 30853354 19 0 13 Locked QAM256 13 507000000 Hz 0.9 dBmV 35.8 dB 30861997 23 0 14 Locked QAM256 14 513000000 Hz 0.8 dBmV 35.5 dB 30871525 25 0 15 Locked QAM256 15 519000000 Hz 0.7 dBmV 35.8 dB 30881585 39 0 16 Locked QAM256 16 525000000 Hz 0.3 dBmV 36.6 dB 30890260 36 0 17 Locked QAM256 17 531000000 Hz 0.5 dBmV 37.1 dB 30909030 38 0 18 Locked QAM256 18 537000000 Hz 0.2 dBmV 37.3 dB 30918286 36 0 19 Locked QAM256 19 543000000 Hz 0.4 dBmV 37.1 dB 30927263 32 0 20 Locked QAM256 20 555000000 Hz 1.0 dBmV 37.2 dB 30936543 46 0 21 Locked QAM256 21 561000000 Hz 0.9 dBmV 36.9 dB 30765945 172563 7225 22 Locked QAM256 22 567000000 Hz 1.9 dBmV 34.9 dB 27083751 1244789 2622102 23 Locked QAM256 23 573000000 Hz 1.2 dBmV 35.9 dB 29799618 731184 428058 24 Locked QAM256 24 579000000 Hz 0.3 dBmV 36.6 dB 30964961 44 0 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 <tabindex=-1>Upstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 35600000 Hz 35.5 dBmV 2 Locked ATDMA 2 29200000 Hz 35.8 dBmV 3 Locked ATDMA 3 22800000 Hz 33.3 dBmV 4 Not Locked Unknown 0 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV <tabindex=-1>Downstream OFDM Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1 25 372000000 Hz 5.2 dBmV 37.8 dB 1108 ~ 2987 898284 9608 0 2 Not Locked 0 0 0 Hz 7.5 dBmV 0.0 dB 0 ~ 4095 0 0 0 <tabindex=-1>Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked Unknown 0 0 Hz 0 dBmV 2 Not Locked Unknown 0 0 Hz 0 dBmV Current System Time: Sat Dec 23 13:12:17 2017
I attached a pdf with the rest.
Warm regards,
Joe Noonan
