jgnoonan
Dec 03, 2017Star
CM1000 Xfinity issues
I am quite frustrated at this point. I had a CM600 modem to support Comcast's Extreme 150 service. I've had it for a few years and was consistently getting 160 to 170mbps speed from it. About thre...
- Mar 12, 2018
Well it is finally fixed. The tech showed up today and I showed him the two frequencies that were having the problem. He checked outside, and then at the tap. He came into the house and said he needed to call a bucket truck in to fix it. I got a recorded call from Comcast that they were working to fix the issue. I got a second call an hour later that the issue was fixed. I ran a speed test and got a consistent 160mbps (yay!). I used the reset button on the modem and let it re-provision. All the signal/noise and power levels were good and there were no uncorrectable codewords. They didn't tell me what they fixed, but at long last, it is fixed.
JonMJones10
Dec 23, 2017Aspirant
I think I'm having the same issue! It's driving me bonkers. Here is what I posted on the Xfinity forums:
Hardware Info:
| Hardware Version | 2.02 |
| Firmware Version | V3.01.04 |
| CM certificate | Installed |
Here is the event log of the past 24 hours:
Note: I removed the MAC addresses, but the CM-MAC and CMTS-MAC do not match.
Latest Log after a factory reset on the modem:
2017-12-23, 09:01:46 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
2017-12-23, 09:00:19 | Notice (6) | CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: E; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
2017-12-23, 09:00:19 | Warning (5) | Unicast DSID PSN startup error |
2017-12-23, 08:59:49 | Warning (5) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=xx:xx:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx;CMTS-MAC=00:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
Here are my current connection stats:
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 729000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
<tabindex=-1>Downstream Bonded Channels
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 21 | 729000000 Hz | 6.2 dBmV | 40.3 dB | 48754675 | 0 | 0 |
| 2 | Locked | QAM256 | 1 | 609000000 Hz | 8.1 dBmV | 41.0 dB | 47253420 | 0 | 0 |
| 3 | Locked | QAM256 | 2 | 615000000 Hz | 7.7 dBmV | 40.9 dB | 47261941 | 0 | 0 |
| 4 | Locked | QAM256 | 3 | 621000000 Hz | 7.9 dBmV | 41.0 dB | 47271046 | 0 | 0 |
| 5 | Locked | QAM256 | 4 | 627000000 Hz | 7.4 dBmV | 40.9 dB | 47280141 | 0 | 0 |
| 6 | Locked | QAM256 | 5 | 633000000 Hz | 7.4 dBmV | 40.6 dB | 47285916 | 0 | 0 |
| 7 | Locked | QAM256 | 6 | 639000000 Hz | 7.2 dBmV | 40.7 dB | 47299161 | 0 | 0 |
| 8 | Locked | QAM256 | 7 | 645000000 Hz | 7.1 dBmV | 40.6 dB | 47307951 | 0 | 0 |
| 9 | Locked | QAM256 | 8 | 651000000 Hz | 6.9 dBmV | 40.5 dB | 47317712 | 0 | 0 |
| 10 | Locked | QAM256 | 9 | 657000000 Hz | 6.9 dBmV | 40.5 dB | 47326996 | 0 | 0 |
| 11 | Locked | QAM256 | 10 | 663000000 Hz | 6.9 dBmV | 40.4 dB | 47336669 | 0 | 0 |
| 12 | Locked | QAM256 | 11 | 669000000 Hz | 7.0 dBmV | 40.6 dB | 47345598 | 0 | 0 |
| 13 | Locked | QAM256 | 12 | 675000000 Hz | 7.1 dBmV | 40.1 dB | 47355716 | 0 | 0 |
| 14 | Locked | QAM256 | 13 | 681000000 Hz | 6.9 dBmV | 40.3 dB | 47363949 | 0 | 0 |
| 15 | Locked | QAM256 | 14 | 687000000 Hz | 7.2 dBmV | 40.6 dB | 47373438 | 0 | 0 |
| 16 | Locked | QAM256 | 15 | 693000000 Hz | 6.9 dBmV | 40.2 dB | 47382707 | 0 | 0 |
| 17 | Locked | QAM256 | 16 | 699000000 Hz | 6.8 dBmV | 40.2 dB | 47380079 | 0 | 0 |
| 18 | Locked | QAM256 | 17 | 705000000 Hz | 6.7 dBmV | 40.5 dB | 47410399 | 0 | 0 |
| 19 | Locked | QAM256 | 18 | 711000000 Hz | 6.4 dBmV | 40.4 dB | 47419980 | 0 | 0 |
| 20 | Locked | QAM256 | 19 | 717000000 Hz | 6.2 dBmV | 40.3 dB | 47428801 | 0 | 0 |
| 21 | Locked | QAM256 | 20 | 723000000 Hz | 5.9 dBmV | 40.3 dB | 47430581 | 0 | 0 |
| 22 | Locked | QAM256 | 22 | 735000000 Hz | 5.5 dBmV | 40.2 dB | 47438250 | 0 | 0 |
| 23 | Locked | QAM256 | 23 | 741000000 Hz | 5.9 dBmV | 40.2 dB | 47444370 | 0 | 0 |
| 24 | Locked | QAM256 | 24 | 747000000 Hz | 5.3 dBmV | 40.1 dB | 47449904 | 0 | 0 |
| 25 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 26 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 27 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 28 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 29 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 30 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 31 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels
| 1 | Locked | ATDMA | 1 | 35800000 Hz | 49.5 dBmV |
| 2 | Locked | ATDMA | 2 | 29400000 Hz | 50.0 dBmV |
| 3 | Locked | ATDMA | 3 | 23000000 Hz | 50.0 dBmV |
| 4 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
<tabindex=-1>Downstream OFDM Channels
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV | 0 dB | 0 ~ 0 | 0 | 0 | 0 |
| 2 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV | 0 dB | 0 ~ 0 | 0 | 0 | 0 |
<tabindex=-1>Upstream OFDMA Channels
Current System Time: Sat Dec 23 09:17:13 2017
jgnoonan
Dec 23, 2017Star
BigQuark OK. I finally got the modem reactivated which took more time that I thought. First, here is the link to the speed test I did. I have 150mbps service and with the Xfinity gateway I was getting a very solid 175mbps. With the CM1000, I'm getting about 80mbps.
http://speedtest.xfinity.com/results/JBJNMFPLV2Q17ZE
I am going to keep the CM1000 connected until we can resolve the issue. Here is the data you requested;
| Acquire Downstream Channel | 441000000 Hz | Locked |
| 1 | Locked | QAM256 | 4 | 441000000 Hz | 3.1 dBmV | 38.0 dB | 32255290 | 8 | 0 |
| 2 | Locked | QAM256 | 1 | 423000000 Hz | 3.7 dBmV | 38.4 dB | 30759191 | 16 | 0 |
| 3 | Locked | QAM256 | 2 | 429000000 Hz | 3.8 dBmV | 38.6 dB | 30769845 | 9 | 0 |
| 4 | Locked | QAM256 | 3 | 435000000 Hz | 3.6 dBmV | 38.4 dB | 30778760 | 10 | 0 |
| 5 | Locked | QAM256 | 5 | 453000000 Hz | 2.3 dBmV | 37.5 dB | 30788847 | 25 | 0 |
| 6 | Locked | QAM256 | 6 | 459000000 Hz | 1.9 dBmV | 37.1 dB | 30797731 | 29 | 0 |
| 7 | Locked | QAM256 | 7 | 465000000 Hz | 1.7 dBmV | 36.6 dB | 30807102 | 16 | 0 |
| 8 | Locked | QAM256 | 8 | 471000000 Hz | 1.3 dBmV | 36.1 dB | 30816615 | 27 | 0 |
| 9 | Locked | QAM256 | 9 | 477000000 Hz | 1.1 dBmV | 35.8 dB | 30825593 | 29 | 0 |
| 10 | Locked | QAM256 | 10 | 483000000 Hz | 0.7 dBmV | 35.6 dB | 30834441 | 41 | 0 |
| 11 | Locked | QAM256 | 11 | 489000000 Hz | 0.6 dBmV | 35.9 dB | 30844020 | 28 | 0 |
| 12 | Locked | QAM256 | 12 | 495000000 Hz | 0.8 dBmV | 36.2 dB | 30853354 | 19 | 0 |
| 13 | Locked | QAM256 | 13 | 507000000 Hz | 0.9 dBmV | 35.8 dB | 30861997 | 23 | 0 |
| 14 | Locked | QAM256 | 14 | 513000000 Hz | 0.8 dBmV | 35.5 dB | 30871525 | 25 | 0 |
| 15 | Locked | QAM256 | 15 | 519000000 Hz | 0.7 dBmV | 35.8 dB | 30881585 | 39 | 0 |
| 16 | Locked | QAM256 | 16 | 525000000 Hz | 0.3 dBmV | 36.6 dB | 30890260 | 36 | 0 |
| 17 | Locked | QAM256 | 17 | 531000000 Hz | 0.5 dBmV | 37.1 dB | 30909030 | 38 | 0 |
| 18 | Locked | QAM256 | 18 | 537000000 Hz | 0.2 dBmV | 37.3 dB | 30918286 | 36 | 0 |
| 19 | Locked | QAM256 | 19 | 543000000 Hz | 0.4 dBmV | 37.1 dB | 30927263 | 32 | 0 |
| 20 | Locked | QAM256 | 20 | 555000000 Hz | 1.0 dBmV | 37.2 dB | 30936543 | 46 | 0 |
| 21 | Locked | QAM256 | 21 | 561000000 Hz | 0.9 dBmV | 36.9 dB | 30765945 | 172563 | 7225 |
| 22 | Locked | QAM256 | 22 | 567000000 Hz | 1.9 dBmV | 34.9 dB | 27083751 | 1244789 | 2622102 |
| 23 | Locked | QAM256 | 23 | 573000000 Hz | 1.2 dBmV | 35.9 dB | 29799618 | 731184 | 428058 |
| 24 | Locked | QAM256 | 24 | 579000000 Hz | 0.3 dBmV | 36.6 dB | 30964961 | 44 | 0 |
| 1 | Locked | ATDMA | 1 | 35600000 Hz | 35.5 dBmV |
| 2 | Locked | ATDMA | 2 | 29200000 Hz | 35.8 dBmV |
| 3 | Locked | ATDMA | 3 | 22800000 Hz | 33.3 dBmV |
| 1 | Locked | 0, 1 | 25 | 372000000 Hz | 5.2 dBmV | 37.8 dB | 1108 ~ 2987 | 898284 | 9608 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 7.5 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
Current System Time: Sat Dec 23 13:12:17 2017
I attached a pdf with the rest.
Warm regards,
Joe Noonan
- irakhlinJan 09, 2018AspirantI don't want to hijack your thread but I just want to add that I am having very similar problems. My internet was having identical issues to yours however on Friday my internet stopped working all together. Since then Comcast has replaced all the lines to my house and inside yet the CM1000 still goes not get any internet. What is weirder is that I am getting an external Comcast IP address assignment but Comcast says they cannot see my modem respond. Additionally connecting their rented equipment and provisioning it to the account works without issue, provisioning the CM1000 back to the account results in no service at all. I am really looking forward to seeing a response on this because I am also out of ideas.
- martyr444Jan 11, 2018Apprentice
I too am havng similar issues with my CM1000. Comcast has tried some of the same changes with my cables but nothing is fixing it. My CM1000 averages 35,000 errors daily both Correctable Codewords and Uncorrectable Codewords. I get error logs and drops daily and my firmware version is v3.01.04. It was doing the same with the previous version but maybe worse now. They just don't seem to know how to fix these issues in our area. Issues with Xfinity just went down hill ever since switching to Docsis 3.1. I have tried a different CM1000 with the same results.
In my case I feel Xfinity is having issues with Docsis 3 in general as thats when our issues started up. We have tried all the brands on the Xfinity list including a loaner from them. I think the CM1000 got worse with the latest firm ware update.
- irakhlinJan 11, 2018Aspirant
I think this is an issue with xfinity and docsis 3.1 modems. I have tested two netgear cm1000 modems and an arris sb8200.. both of these are the top of the line docsis 3.1 modems and all 3 had identical issues at my house. The second I went out and got an arris sb6190 (one of the fastest docsis 3.0 modems) everything worked perfectly. It also worked perfectly with the rental modem which was also docsis 3.0. I think its fair to say this issue is isolated to docsis 3.1 modems.. atleast on my network.
- BigQuarkJan 18, 2018Guide
My log now has bursts of errors. It may be a 1 or 2 or 3 hour time frame that peppers my Cm1000 error logs, then it clears up. After calling Comcast several times I am convinced the customer service reps are starting to hear more and more of CM1000 issues when using D3.1 Mine modem was just fine on the 24x3 D3.0 but went haywire when the firmware was updated and a D3.1 D/S channel was deployed in my area.
I am on a Cisco CMTS judging by my CMTS MAC and I think that is where the problem lies. Comcast had a similar problem whith the Motorola SurfBoard 8200 activating on Gigabit Tier. The problem was the CMTS and a Comcast Engineer had to log into the CMTS and manually activate the 8200's. That issue has largely been resolved but that is what leads me to believe this also is a CMTS issue. Still no resolution, however.
