Vwrabbit23's avatar
Mar 28, 2024
CM100v2 REBOOT LOOP
Since Xfinity started their 10G network upgrade my modem won't connect and will reboot several times before it stop. In order to get the modem to connect and stay connected is to manually specify a ...
  • plemans's avatar
    Mar 29, 2024
    Not sure what splitter you added but you dropped quite a few points on the downstream and increased your upstream to a level that can potentially cause errors.
    If you used a double/triple splitter, pull it back out, as it shouldn't be dropping power that much and putting that much resistance in line.
    If it were me, I'd directly connect it to where the coax comes in, and when you get the errors, call xfinity and have them come check the line. By directly connecting it, you ensure there isn't anything in the home causing issues that xfinity can bill you for.
