eddiebear
Sep 17, 2015Aspirant
Cm500 disconnection issues
My cm500 seems to work perfectly fine all day till late evening when it resets constantly. I have an ac1200 router and it does not reset. Wondering if there is anything I can do to fix this?.
- Sep 18, 2015
Hello eddiebear
My guess is could be the signal levels on the modem or it could be a area issue with your ISP late evening is mostly when people in your area would be home and all online. I would just double check your cable line connections make sure they are good and contact your ISP to run some diagnostics check all the signal strength and maybe send a tech out to do some adjustments if needed. Hope to hear your feedback.
DarrenM
eddiebear
Oct 03, 2015Aspirant
right now I seem to be fine so maybe its ok now?
