CKnight90
Jun 26, 2025Tutor
Uncorrectable Errors - Tech Questions
Few months ago I had issues with games randomly disconnecting. This started to happen after a wind storm that came through the area. I noticed DS OFDM channels had Uncorrectables. So I checked all my...
Kitsap
Jun 26, 2025Master
Based on your tag, I presume your modem is the Netgear CM1200. Please confirm. Your signal power levels are definitely high.
The columns for correctables/uncorrectables reset to zero when you reboot your modem. Knowing the system uptime for the period the values accumulated is helpful in keeping the numbers in perspective. Knowing if they accumulated over two hours, two days, two weeks, or two months provides a more complete picture. See the bottom two lines of the cable connection page.
Some good background information can be found here: https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html.
Duckware is a solid reference.
