MChang1
Feb 14, 2026Aspirant
Understanding how CAX80 works
I have this with xfinity internet. I have the two wifi networks set up, 2.4 & 5. The router/modem is in one end of the house. I can get a wifi signal on my TV in my bedroom through ROKU that is lo...
schumaku
Feb 14, 2026Guru - Experienced User
MChang1 wrote:TV in my bedroom through ROKU that is loaded on the TV
Some kind of Roku TV with either "Roku built in" or "Made by Roku"? Search accordingly for the related Roku Smart TV data sheet as StephenB already suggested.
MChang1 wrote:Works OK< Netflix speed is very low, but works.
Low according to what - the built-in test on some Roku devices or TVs? Netflix recommends for high definition (HD) @720p 3 Mbps or higher, full high definition (FHD) @1080p 5 Mbps or higher, ultra high definition (UHD) @4K 15 Mbps or higher.
This is far less than what average 2.4 GHz WiFi can achieve...
- MChang1Feb 14, 2026Aspirant
According to the test on the Roku app that came with the TV the connection is good, but the speed is 6.54 thanks brian
