ezou
Sep 09, 2016Aspirant
ReadyShare DLNA Server Disconnects during music streaming
Hi, I have connected a Seagate Backup 2T USB drive to Netgear CableModem router (C3000) to serve as media server. On the player side, I connected a Marantz NA8005 network music player to the router...
boxcar-7
Oct 12, 2016Guide
Hello, you are most likely having the same difficulty I was having. I also wanted to stream from my Seagate 2TB Slim Hard Drive, and every time I did it stopped. This is because the drive is drawing power through the USB from your router. That interrupts the data streaming. I tested the router with different drive that had its own external power the movie played just fine from start to finish. So, I looked into externally powering my Seagate 2TB Backup Slim with 3.0 USB drive. Here is what I found: https://www.sabrent.com/product/EC-DFLT/usb-3-0-sata-external-hard-drive-lay-flat-docking-station-2-5-3-5in-hdd-ssd Or something similar. I believe this will solve our problem. I asked the question on a different community post and waiting to hear from them. I asked the question to Sabrent, they weren't sure, asked Seagate, they thought issues, I'm just now waiting to hear from Netgear support before I spend the dollars. Hope this helps and good luck. Boxcar-7....
boxcar-7
Oct 12, 2016Guide
Edit to correct..."asked Seagate, they thought there should be no issues" Boxcar-7
