rogercnewman
Aug 26, 2017Aspirant
READYSHARE not recognizing USB
My N450 will not recognize any USB device I attach to it, including the WD My Book which is in the compatible list. I am not very patient, but have waited for 2 days for it to show up!
DarrenM
Aug 28, 2017Sr. NETGEAR Moderator
Hello rogercnewman
What is the format of the Harddrive?
DarrenM
rogercnewman
Aug 29, 2017Aspirant
All the drives I have tested are NTFS.
- DarrenMAug 31, 2017Sr. NETGEAR Moderator
It could be a bad usb port on the unit if its not picking up anything that you are plugging into it you will need to contact support.
http://www.netgear.com/support/contact.aspx
DarrenM
