Joshipp's avatar
Joshipp
ReadyShare USB Drive - Unable to Write to Drive from MacBook Pro
I can connect to and read my files with no problem from the connected USB drive. My problem is when I try to write to the drive. First it asks me to log in. The only login it will accept is the user login for my Mac but when I use this login it errors out saying "That operation can't be completed because you don't have the necessary permission." If I login to the C7800 Nighthawk Router and access the ReadyShare storage, the write access for the drive is set us as "All - No Password".
My router is running firmware version 6.01.07. I have tried resetting the router, my compter, etc. I have tried changing the read & write access to password protected and then back. None of this worked.
Please HELP! I just upgraded to this router and the drive worked perfectly on our old system so I know that it isn't a problem with the drive.
