Jeannemac's avatar
Jeannemac
Replacement for the CG3000D
what is the best replacement for the CG3000D modem/router to be able to take advantage of Cox's higher speeds
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Jeannemac
    All these modems can take advantage of the 250Mbs speeds comcast offers.
    ·         Netgear C6250 Cable Modem Router
    ·         Netgear C6300 Cable Modem Router
    ·         Netgear C7000 Cable Modem Router
    ·         Netgear CM500 Cable Modem
    ·         Netgear CM600 Cable Modem
    DarrenM
    • Jeannemac's avatar
      Jeannemac
      Thanks for the info.  Are all these wifi modem/routers?
      • DarrenM's avatar
        DarrenM
        Jeannemac
        The first 3 are.
        DarrenM
