Adewale
Aug 13, 2018Luminary
Replacement for Xfinity Router?
HI everyone,
can nanyone advise a suitable modem replacement for the Xfinity leased modem/router combo that comes with my subscription? i will like to save on the $11 i pay to lease the equipme...
vkdelta
Aug 13, 2018NETGEAR Employee Retired
CM500V (This is ONLY a Modem + Voice) and NOT a Router. You will need a seperate Router.
This works for upto ~250/300 Mbps (currently as per Comcast provisioning standards)..
- AdewaleAug 14, 2018Luminary
thanks for the response and yes it seems to be the only netgear modem with voice capability i can find anywhere. however, it cannot achieve the speed you quoted...its actually rated at less than or just about 50Mbps
- vkdeltaAug 14, 2018NETGEAR Employee Retired
https://mydeviceinfo.xfinity.com/device/netgear-cm500v-629
as per Comcast certification it is rated for 250/300 Mbps.
- AdewaleAug 15, 2018Luminary
thanks for the info..very much appreciated
