SugarlessGrub5
Jul 30, 2020Aspirant
Replacement power adapter for CM1000v2
Where could I purchase a replacement power adapter for the CM1000v2 cable modem? Any help would be appreciated.
Jul 30, 2020Guru - Experienced User
Try places let Amazon. Look for same spec voltage and amps as listed on the sticker of the power adapter.
SugarlessGrub5
Does it have to be a Netgear power adapter? Will the modem be compatible with any power adapter as long as the volts and amps are correct?
- FURRYe38Jul 30, 2020Guru - Experienced User
Correct, as along as the volts, amps and size of plug are the same, the modem will work fine with non NG branded power adapters.
- SugarlessGrub5Jul 30, 2020AspirantWhat do you mean by size of the plug? Are you talking about the part that plugs into the modem? If so, how would I be able to find out if it would fit before buying?
