Mrbelk's avatar
Mrbelk
Tutor
Apr 04, 2021
Resetting Router Mode C3000
I was troubleshooting an issue and arbitrarily changed the router mode to no. This was a not so smart move. Now the router doesn’t show on my list of available networks. I’ve tried doing a factory reset by pressing the reset button on the bottom but that doesn’t seem to work. I need reset the router mode back to yes but since it doesn’t show, I cannot access the modem at all. Any ideas ? Appreciate your help.
  • plemans's avatar
    connect 1 device to the c3000 ethernet port, disconnect the other devices from it. Then reboot the c3000.
    Then go to 192.168.100.1
    that should let you access the c3000 and re-enable router mode.
    You can try a factory reset as well. Many times people don't push and hold for 7-15 seconds while powered on.
    • Mrbelk's avatar
      Mrbelk
      Tutor
      I appreciate the tip and sorry it took me so long to get back to the issue.  As it turns out my PC does not have an ethernet port and I cannot locate a USB to USB cable in my stash to see if I can connect that way.  I also tried the reset button again.  When I press, hard, the button does not seem to give at all, so I can't tell if the reset is actually working.  Do you actually see or feel movement when you press the reset button?
      • FURRYe38's avatar
        You would need a USB to Ethernet adapter to connect to the modem with your PC.
