interessant's avatar
interessant
Follower
Mar 27, 2026
Right now i can not log in to router to see the settings i set
using it right now ....however found info ....port forwarding ....right now i can not log in to router to see the settings i set.....
posts on netgear webside got deleted....
1 Reply
  • CrimpOn's avatar
    CrimpOn
    interessant wrote:
    using it right now
    One of the problems with piggybacking on a conversation that ended seven years ago is that the context is essentially ambiguous.  i.e.
    • Is this about a Netgear C6250 ?
    • Have you purchased a DOCSIS 3.1 modem and connected it to one of the C6250 Ethernet ports?
      If so, specifically what modem is this?
    • How have you established that this is "working"?
    • How are you not able to log into the router?
