MrPlebbian
Apr 20, 2020Aspirant
RMA Return
I recently had an RMA approved and decided to pay to receive the replacement first and then send mine back. It was supposed to come with a return label but there wasn’t any clearly visible on the pack...
TrumpKing
May 05, 2020Aspirant
How did you solve the problem? It seems that I also encounter similar problem with USPS.
MrPlebbian
May 06, 2020Aspirant
I honestly simply hoped that the next delivery attempt would work and if it didn't then I would have thought of contacting Netgear for some sort of compensation since it wouldnt have been my fault. Luckily the next delivery attempt did work and about two days later they processed my rma and all was well. I hope the same happens to you!
- FURRYe38May 06, 2020Guru - Experienced User
Glad you got this resolved. Thank you for letting us know.
MrPlebbian wrote:I honestly simply hoped that the next delivery attempt would work and if it didn't then I would have thought of contacting Netgear for some sort of compensation since it wouldnt have been my fault. Luckily the next delivery attempt did work and about two days later they processed my rma and all was well. I hope the same happens to you!
