ldyork
Apr 07, 2018Tutor
Router Compatibility with Crestview Cable
Can anyone tell me if this cable/Wifi/voice router (C7100V-1AZNAS) works with Crestview Cable/voice?
vkdelta
Apr 11, 2018NETGEAR Employee Retired
dont buy. it wont work.
this product is heavily customize to work with XFINITY/Comcast *ONLY*.
I suggest not to waste your time and money. on top of that, I suggest not to buy any other devices from retail unless your ISP says it is supported.
your best bet is to seperate voice and data using 2 different modems.
- ldyorkApr 11, 2018Tutor
Thanks for the response. My question exactly related to xfinity although Crestview did answer my call and said all gateways except Motorola and one I forget would work including Netgear. The C7000B sounds like a great solution but not available for mere mortals only ISP's.
Just remembered. The other one not recommended was Zoom.
