Nixi's avatar
Nixi
Follower
Mar 03, 2017
Router Modem Combination
will the netgear DSL Modem d200 work with the new R9000 x10 wireless router on a BT LINE England
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Nixi
    The R9000 should work with all modems via ethernet connection as for the d200 you may want to check with the ISP if that is a supported modem.
    DarrenM
