AK77
Oct 19, 2017Follower
Router, netgear Dead.
Discovered that our router has died. Can’t seem to find a reason why. No lights on, nada. Did the reset, turned everything off, etc and still nothing.
antinode
Oct 19, 2017Guru
> [...] our router has died. [...] No lights on, nada.
Do you have access to a voltmeter (or a small 12V light bulb)? Is
the AC adapter dead, or the router itself?
If the thing is getting no power, then I wouldn't bet that you
actually "Did the reset" (whatever that means).
