sp4cem0nkey's avatar
sp4cem0nkey
router randomly drops internet on one wifi device
For months now, my C7000-100NAS wifi router has been randomly dropping the internet for my MacBook Pro multiple times per day.  This happens on the regular and 5G access points. I work around this by disabling/enabling wifi.  I thought this was a wifi connectivity issue at first, but here's the kicker:
I can still connect over wifi to my router's Genie admin portal!  I can switch pages and make configurations like normal even while I can't access Google or any other site.  I've tried pinging IPs too, and this also fails until I've re-connected.  Why on earth would I be able to access my router over wifi but not the internet?
This problem does not happen to any of the other wifi devices in my household, nor does it happen to my macbook when cabled in.
Router model: C7000-100NAS
Router firmeware: V1.01.15
ISP: Spectrum (their support tech claims I have the latest firmware version available from Spectrum)
  • Spectrum recently upgraded my router firmware to V1.01.23, and this seems to have fixed the problem.  :cathappy:
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Sp4cem0nkey
    Have you made sure the MAC has the latest wireless drivers?
    DarrenM
    • antinode's avatar
      antinode
      Guru
      > [...] Why on earth would I be able to access my router over wifi but
      > not the internet?
         Sounds like a router problem, doesn't it?
      > [...] I've tried pinging IPs too, and this also fails until I've
      > re-connected.
         That would seem to rule out a DNS problem.  If you can reach the
      router, but not "ping" any outside-world system, even by IP address
      (assuming that you're using a valid one -- 8.8.8.8 is popular), then
      it's a mystery.
         No Access Control, Parental Control, or Schedule settings to cause
      trouble?
      > [...] nor does it happen to my macbook when cabled in.
         Same IP address, or different?
         When things get especially squirrelly, it may be time to try a full
      ("factory") reset (and reconfiguration) of the router.
         It's a Mac[intosh] not a Media Access Control, and the typical user
      has approximately no control over any device drivers, other than
      whatever Apple Software Update does.
    • sp4cem0nkey's avatar
      sp4cem0nkey
      Dang it!  It started happening again.  I'm going to buy another brand of router.  This is ridiculous.
