Pei's avatar
Pei
Follower
Jul 18, 2016
Router went back to admin/password, I need to set up a password.
After I downloaded Windows 10 I discovered the router wasn't password protected any longer. I need to create a passoword but don't know how to do it, the cable guy did it when he set it up a couple years ago. I called the cable company but they said I'd have to sign up for their premium protection package for an extra $30 a month. Help! How do I do this? Thanks, Pei
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Pei
    If you can not get into the router settings you will have to do a factory reset which will wipe all the settings and then you would have to set up the router again and the default login would be admin/password. To do a factory reset you just need to hold in the reset button with a paper clip or pen for 10 seconds on the back of the router.
    DarrenM
