Barbraela2
May 06, 2018Follower
Router without wifi
Can I get a router to use but turn the wifi off? I don't need wifit and right now not using a router but then read that is not good, so looking for one. Tech-challenged. Thanks
DarrenM
May 08, 2018Sr. NETGEAR Moderator
Yes you can disable the wifi on our routers if needed.
DarrenM
