MrKip's avatar
MrKip
Follower
Apr 27, 2016
Security Cameras
Hi
I have a net gear C6300.  Im using wifi set at 2.4G
i have bought 2 different security cameras neither will connect.  Both supports claim its my router
1 was a Guardzilla
2 was a Guardcam
do only certain cameras work with Netgear?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Mrkip
    There should be nothing the router is doing to block these cameras. Im not familiar with those 2 cameras but have you looked to see if any type of port forwarding needs to be used for these to work.
    DarrenM
