Sandibear764
Feb 23, 2016Aspirant
Security issues with C6300 Cable Modem
I have received numerous DoS ICMP Flood attacks through my C6300 Cable Modem. I have tried changing passwords, SSID Name, factory resets. Still I am having security issues.!Comcast has suggested that to fix the problem I would need to replace the modem. Is there a way to secure the modem short of purchasing an entirely new modem?
- DarrenMSr. NETGEAR Moderator
Hello Sandibear764
Typically those attacks are when they have your Ip address does the log say what Ip these attacks are coming from?
DarrenM
- Sandibear764AspirantHi Darren, thanks for responding. Yes, the event log listed 4 different IP addresses as sources. They are: 193.238.98.90; 185.94.111.1; 195.251.255.69; 203.178.148.19; and 206.117.25.90. I received multiple attacks from at least two of these IP addresses.
- Sandibear764AspirantThanks Darren, I got your message. I'm baffled by this information and how they connected with me. Anyway, thank you for all of your help. Now time to put things back to right.
- jpoorboyAspirant
Hello,
I am seeing the same issue as OP.
I have had my ISP come out and test my lines and no line noise, but my speeds are dropping.
Seeing lot's of IP's listed in the logs.
Please help!
Hello jpoorboy
Can you post the logs might be able to help.
DarrenM
- jpoorboyAspirant
Hello Darren.
Sorry for the delay.
I changed my IP to 0.0.0.0 in the log snipit I have provided below.
Description Count Last Occurrence Target Source [DoS attack] ICMP Flood from 219.144.128.59 1 Wednesday, 26 Jul 2017 16:07:44 0.0.0.0 219.144.128.59 [DoS attack] ICMP Flood from 54.94.201.10 1 Wednesday, 26 Jul 2017 13:57:11 0.0.0.0 54.94.201.10
