DERoss
Jun 21, 2017Apprentice
Security Update from NETGEAR?
This morning (21 June 2017), I received an E-mail message with the Subject: "Important Security Update from NETGEAR: New Firmware Is Available for Your Product". For the following two reasons, I suspect this is a fake.
1. Nowhere in the Netgear Web site can I find any reference to a late June report of a security vulnerability.
2. When I open my router configuration, select Advanced and then check for updates, none are found.
Is this a real message from Netgear? If yes, why cannot I find the update? If not, I have saved the message if Netgear would like to investigate.
- thenryAspirant
I received one of these as well. Is it legit?
The sticker on my router says model B90, but the email says model WNR2000v3.
- HCEAspirant
I have received the same email but want to know if it is a scam before doing anything
- User8472Aspirant
The email was sent from a Netgear IP address, so I'm guessing it's legitimate. However there was no new firmware update or security patch for my PR2000. Seems like a major screwup by Netgear. However there is no method of contacting their support dept and I really doubt their staff even looks at these forums. I doubt we'll ever have an answer. EPIC NETGEAR SUPPORT FAIL.
I'm really interested in the security vulnerability, I don't want to be exposed to attack.
- DERossApprentice
The origiinal message source indicates the message was sent from a server with the IP address 136.147.187.62. A WhoIs query indicates that IP address belongs to either Salesforce.com, Inc. in San Francisco or else ExactTarget, Inc. in Indianapolis. According to Wikipedia, ExactTarget was the original name of Salesforce.com; but neither is connected to Netgear.
The return E-mail address domain was NOT netgear.com but e.netgear.com. A DNS lookup for netgear.com yields the IP addresses 54.200.99.0 and 54.218.118.186, both of which belong to Amazon. A DNS lookup for e.netgear.com, however, yields the IP address 68.232.201.28, which belongs to ExactTarget.
Since the US-CERT (an agency of the United States Department of Homeland Security) has not reported a Netgear security vulnerability for June, this whole mess smells.
- UKuserAspirant
So have I.
I live in the UK - unable to find any phone number for netgear to check if it is a scam.
Tried several times to make a new post without success - just a message saying try again later - I suspect they are overwhelmed with concerned users and just can't cope.
Get some phone contact netgear or you will lose business.
Customer service = pathetic.
- netwrksMaster
UKuser wrote:So have I.
No need to call. Just go here: https://www.netgear.com/support/ - Plug in you router name and check to see if there is a new fw version..
