rebeccar's avatar
rebeccar
Selecting frequency C3700 Modem/router
Wireless printer, TV and Thermostat all operate on 2.4 Ghz only in my home. MacBook Pro, iPhones and iPad can connect at either 2.4 or 5 Ghz. How to determine the best frequency for these mobile devi...
  • VE6CGX's avatar
    VE6CGX
    May 09, 2016
    Selecting channel is from the router config page when you log into the router. If all devices are working well then don't worry for the time being. 2.4GHz band is more crowded so devices on that band could have issues some times but 5GHz band is relatively quiet so as much you can use 5GHz band. Only difference between two bands is 5GHz band has typically less range due to higher frequency it uses.
