rickthefix
May 16, 2016Novice
setting gateway/wireless router to modem only
tried setting up c3700 as modem only, then connected new/faster wireless router to jack, but the WAN light on the router does not light up. I could not even connected to the c3700 with a wired connec...
DarrenM
May 24, 2016Sr. NETGEAR Moderator
Hello rickthefix
You may want to remove the coax connection try to set the it to modem only and then reconnect the coax see if that fixes the issue.
DarrenM
