Kyleegrace2115's avatar
Dec 14, 2019
Setting up a new modem
I tried to connect my new modem I just bought when my old century link modem stopped working, but now it will not connect to my internet and I dont know why
  • plemans's avatar
    Did you contact your ISP to get it provisioned?
    Are you sure its compatible with your service?  Thats kind of a key. Contact your isp to see if its compatible as well as to get it provisioned.
  • michaelkenward's avatar
    michaelkenward
    If you are trying to set up a new modem, then you need to check the documentation for that device and not just throw an app at it. (I assume that this is what you did as your message is in the section of this community given over to apps.)
    As well as following the advice from plemans, you might get more appropriate and quicker replies, and find other answers, over in the appropriate section for your device:
    Cable Modems & Routers
    • antinode's avatar
      antinode
      Guru
      > modem stopped working, [...]
         What was your "my old century link modem?  How was it configured?
      What is your "my new modem"?
      > Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
         I would not expect CenturyLink to be involved with a "Cable Modem
      Router"  Perhaps you should begin again, this time with a more accurate,
      precise, and complete description of the equipment involved.
         For instructions on configuring a Netgear device, visit
      http://netgear.com/support , put in your (actual) model number, and look
      for Documentation.  Get the User Manual (at least).  Read.
         I fear to ask what "stopped working" actually means, or whether a
      replacement was required.
      > [...] you might get more appropriate and quicker replies, and find
         The "Cable Modems & Routers" forum migh make sense if you actually
      have a cable-TV-type ISP connection, which I would not expect from
      CenturyLink.
