edpnw
Mar 30, 2024Aspirant
Simulated Sine Wave UPS?
Hello -- In buying a new UPS for my C7800 WiFi Cable Modem Router, I'm wondering if I can get by with a cheaper simulated sine wave UPS or if I should buy a full sine wave UPS. Or, for that matter, e...
- Mar 31, 2024
I would think any good quality UPS that provides power specs for the modem should work. APS makes good quality UPS.
Mar 31, 2024Guru - Experienced User
edpnw
Mar 31, 2024Aspirant
First, thank you.
Second, I've no clue of the way things are done here. Is it proper to thank you in this forum? Do people just ignore responses and go along their day?
- FURRYe38Apr 01, 2024Guru - Experienced User
Yes of course. It's up to people to respond to posts.
Good Luck.
