ADOGG302
May 26, 2020Follower
Slow internet speeds
I have a Comcast internet Pro+ plan. It is the 1000Mbps service. I consistently see speeds at around 200Mbps or slower when testing with the Nighthawk app for the Router. Speedtest.net tests on pc's...
AdeptMaven
May 26, 2020Guide
It's a bit of a hassle but you can also rent one of Comcast's gateways for a day or two and have it provisioned and compare speeds. If you get similar speeds then you know for sure its an issue with comcast provisioning or your cable lines. If the speed is much faster then you know the culprit is your equipment
Redcape
Jul 14, 2020Aspirant
the reason I bought my own equipment is because I already tried their equipment and it sucked. I would assume most people who buy their own equipment do so because of the problems with their equipment.
