ADOGG302
May 26, 2020Follower
Slow internet speeds
I have a Comcast internet Pro+ plan. It is the 1000Mbps service. I consistently see speeds at around 200Mbps or slower when testing with the Nighthawk app for the Router. Speedtest.net tests on pc's...
Jul 14, 2020Guru - Experienced User
Any progress on this?
ADOGG302 wrote:I have a Comcast internet Pro+ plan. It is the 1000Mbps service. I consistently see speeds at around 200Mbps or slower when testing with the Nighthawk app for the Router. Speedtest.net tests on pc's usually show slower than that. Comcast claims they see 900Mbps and are blaming my equipment I just purchased and the settings in them. Is there in fact any settings that can be adjusted? Or, as I suspect, this is a Comcast issue I must continually fight until I find the right person who will find and fix it? Thanks
