CooyonLA
Jul 15, 2020Aspirant
Slow Speeds - Xfinity Gigabit Internet
Looking for help:
Since i upgraded to gigabit service with xfinity, I haven't topped 100mbps download speeds. I'll provide my cable connection stats below to see if someone can provide input. After researching for hours, I've realized that majority of my connections are pretty good. The only thing that sticks out is the correctable Downstream OFDM Channels. I don't really understand what that means, I'm just trying to figure out the culprit of the slow speeds (wiring of my house or a technical issue that can be resolved with Xfinity/Netgear support)
Stats below:
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 645000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 37 | 645000000 Hz | 4.8 dBmV | 41.4 dB | 586828586 | 0 | 0 |
| 2 | Locked | QAM256 | 9 | 477000000 Hz | 7.1 dBmV | 42.8 dB | 585596267 | 0 | 0 |
| 3 | Locked | QAM256 | 10 | 483000000 Hz | 7.0 dBmV | 42.8 dB | 585600351 | 0 | 0 |
| 4 | Locked | QAM256 | 11 | 489000000 Hz | 7.0 dBmV | 42.8 dB | 585604304 | 0 | 0 |
| 5 | Locked | QAM256 | 12 | 495000000 Hz | 7.1 dBmV | 42.9 dB | 585607991 | 0 | 0 |
| 6 | Locked | QAM256 | 13 | 501000000 Hz | 7.1 dBmV | 42.8 dB | 585611062 | 0 | 0 |
| 7 | Locked | QAM256 | 14 | 507000000 Hz | 7.1 dBmV | 42.8 dB | 585615382 | 0 | 0 |
| 8 | Locked | QAM256 | 15 | 513000000 Hz | 7.3 dBmV | 42.7 dB | 585618647 | 0 | 0 |
| 9 | Locked | QAM256 | 16 | 519000000 Hz | 7.2 dBmV | 42.7 dB | 585624278 | 0 | 0 |
| 10 | Locked | QAM256 | 17 | 525000000 Hz | 7.3 dBmV | 42.8 dB | 585627827 | 0 | 0 |
| 11 | Locked | QAM256 | 18 | 531000000 Hz | 7.3 dBmV | 42.8 dB | 585631655 | 0 | 0 |
| 12 | Locked | QAM256 | 19 | 537000000 Hz | 7.2 dBmV | 42.8 dB | 585635557 | 0 | 0 |
| 13 | Locked | QAM256 | 20 | 543000000 Hz | 7.1 dBmV | 42.7 dB | 585639226 | 0 | 0 |
| 14 | Locked | QAM256 | 21 | 549000000 Hz | 7.2 dBmV | 42.6 dB | 585642270 | 0 | 0 |
| 15 | Locked | QAM256 | 22 | 555000000 Hz | 7.0 dBmV | 42.5 dB | 585647155 | 0 | 0 |
| 16 | Locked | QAM256 | 23 | 561000000 Hz | 6.9 dBmV | 42.3 dB | 585650509 | 0 | 0 |
| 17 | Locked | QAM256 | 24 | 567000000 Hz | 6.6 dBmV | 42.3 dB | 585656884 | 0 | 0 |
| 18 | Locked | QAM256 | 25 | 573000000 Hz | 6.4 dBmV | 42.3 dB | 585660798 | 0 | 0 |
| 19 | Locked | QAM256 | 26 | 579000000 Hz | 5.9 dBmV | 42.1 dB | 585664713 | 0 | 0 |
| 20 | Locked | QAM256 | 27 | 585000000 Hz | 5.8 dBmV | 42.0 dB | 585668219 | 0 | 0 |
| 21 | Locked | QAM256 | 28 | 591000000 Hz | 5.8 dBmV | 41.9 dB | 585671725 | 0 | 0 |
| 22 | Locked | QAM256 | 29 | 597000000 Hz | 5.5 dBmV | 41.6 dB | 585675660 | 0 | 0 |
| 23 | Locked | QAM256 | 30 | 603000000 Hz | 5.3 dBmV | 41.5 dB | 585679092 | 0 | 0 |
| 24 | Locked | QAM256 | 31 | 609000000 Hz | 4.9 dBmV | 41.5 dB | 585682250 | 0 | 0 |
| 25 | Locked | QAM256 | 32 | 615000000 Hz | 4.4 dBmV | 41.3 dB | 585686915 | 0 | 0 |
| 26 | Locked | QAM256 | 33 | 621000000 Hz | 4.2 dBmV | 41.1 dB | 585689760 | 0 | 0 |
| 27 | Locked | QAM256 | 34 | 627000000 Hz | 4.2 dBmV | 41.1 dB | 585693651 | 0 | 0 |
| 28 | Locked | QAM256 | 35 | 633000000 Hz | 4.4 dBmV | 41.0 dB | 585698102 | 0 | 0 |
| 29 | Locked | QAM256 | 36 | 639000000 Hz | 4.5 dBmV | 41.0 dB | 585701535 | 0 | 0 |
| 30 | Locked | QAM256 | 38 | 651000000 Hz | 4.8 dBmV | 41.2 dB | 585703383 | 0 | 0 |
| 31 | Locked | QAM256 | 39 | 657000000 Hz | 4.8 dBmV | 41.4 dB | 585704539 | 0 | 0 |
| 32 | Locked | QAM256 | 40 | 663000000 Hz | 5.1 dBmV | 41.4 dB | 585706410 | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| 1 | Locked | ATDMA | 1 | 35800000 Hz | 47.3 dBmV |
| 2 | Locked | ATDMA | 2 | 29400000 Hz | 47.3 dBmV |
| 3 | Locked | ATDMA | 3 | 23000000 Hz | 47.3 dBmV |
| 4 | Locked | ATDMA | 4 | 16600000 Hz | 47.3 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1 | 159 | 690000000 Hz | 5.7 dBmV | 40.0 dB | 1246 ~ 2849 | 442088587 | 9941739 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 6.4 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| 1 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
Any feedback would be greatly appreciated!
- CooyonLAAspirant
Just realizing it cut off
<tabindex=-1>Downstream OFDM Channels</tabindex=-1> Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1 159 690000000 Hz 5.7 dBmV 40.0 dB 1246 ~ 2849 442088587 9941739 0 2 Not Locked 0 0 0 Hz 6.4 dBmV 0.0 dB 0 ~ 4095 0 0 0 Correctable Codeword= 9941739
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.- plemansGuru - Experienced User
How are you testing this?
do you have a pc hardwired into the modem?
What pc is it? Is it a gigabit pc?
Have you checked the cable to ensure it supports gigabit? standard cat5 doesnt. Cat5e does
What site are you speedtesting on?
I've had the isp provision a modem wrong. Might be worth checking with xfinity to ensure it has the proper provisioning.
