Aneibauer
May 20, 2025Aspirant
Slow WiFi Cax30 xfinity
I just installed a Cax30 with Xfinity wifi. Speed going into the router is about what it should be near 400, but wifi coming out is around 80. I tried different locations etc, but wonder if there a...
- May 21, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
May 20, 2025Guru - Experienced User
2.4Ghz isn't as fast as 5Ghz.
Try enabling Smart Connect.
