Aneibauer
May 20, 2025Aspirant
Slow WiFi Cax30 xfinity
I just installed a Cax30 with Xfinity wifi. Speed going into the router is about what it should be near 400, but wifi coming out is around 80. I tried different locations etc, but wonder if there a...
- May 21, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
May 21, 2025Guru - Experienced User
That 80mbps is about all you can expect from 2.4ghz. Its a mure slower network and sensitive to interference. 5/6ghz are both significantly faster (multigig speeds if close enough). I usually only put my IoT devices on the 2.4ghz and make sure my streamings and those devices that roam are on the 5ghz.
Aneibauer
May 21, 2025Aspirant
Thanks. I didn’t realize that the slower speed was to be expected. I am impressed with the 5ghz speed and will put my TV on it as well.
- FURRYe38May 21, 2025Guru - Experienced User
Enjoy. 📡
