Aneibauer
May 20, 2025Aspirant
Slow WiFi Cax30 xfinity
I just installed a Cax30 with Xfinity wifi. Speed going into the router is about what it should be near 400, but wifi coming out is around 80. I tried different locations etc, but wonder if there a...
- May 21, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Aneibauer
May 26, 2025Aspirant
Just wanted to report. Been running the Nighthawk for a few days now. The speed issue that I had no longer exists. Running two televisions, laptop, iPhone and iPad at 5ghz, my printer at 2,4. With Xfinity plan of 400, I get a speed test on the iPad as high as 453. Printing has been no issue….other than mistakenly first connecting it to 5ghz.
May 27, 2025Guru - Experienced User
Glad it's working good. Enjoy.
