cybernigel
Dec 11, 2017Aspirant
Slow Wireless / Fast Wired
For my AC1600 (model C6250) speed test with ethernet cable is 120Mbps down, but with 2.4Ghz wireless from 5 feet away it is only 20Mbps. Any suggestions?
- DarrenMSr. NETGEAR Moderator
Hello cybernigel
Have you tried to adjust the wireless channel on the 2.4ghz?
DarrenM
- cybernigelAspirant
Hi David,
I appreciate the reply. What specific adjustments to the 2.4Ghz channel are you suggesting?
Thank you
This Kb may help you with this just apply the same method it outlines to the 2.4ghz network.
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
