FrankAngel
Mar 13, 2023Aspirant
Slower Internet Speed with New CM2000 Cable Modem
I recently switched out an older Netgear CM600 Cable Modem for a CM2000 model. My Xfinity plan gets me 1G speed, which the old modem did not do (only up to 400). A Netgear R6300 wireless router is co...
- Mar 16, 2023
I replaced the router with a Nighthawk Mesh router and all is well. I'm now getting the gigabit speed that I expected. Thanks all for your help.
Mar 13, 2023Guru - Experienced User
Though it had 1Gb ports, it may have not had the NAT HW accelleration support to see anything near 900Mpbs on a ethernet connection. Wireless would be severly limiting on this model as well. Probably need to swap out the R series router for something newer.
Kitsap
Mar 13, 2023Master
From a technology standpoint, your R6300 (pre Nighthawk) is way long in the tooth and outdated by current cable internet throughput. Agree with FURRYe38 , time to look for some new router hardware compatible with your new modem and internet service.
- FrankAngelMar 13, 2023Aspirant
Although the Netgear support person said it should be compatible with the higher speeds, you're probably correct. Any suggestions for a replacement Netgear wireless router?
Oops, just saw the router you're using.
- FURRYe38Mar 13, 2023Guru - Experienced User
Try a RAX30 or 50 series. If you home is bigger or larger, you might consider something MESH like a MK60, 70 or 80 series.
- FrankAngelMar 16, 2023Aspirant
