FrankAngel
Mar 13, 2023Aspirant
Slower Internet Speed with New CM2000 Cable Modem
I recently switched out an older Netgear CM600 Cable Modem for a CM2000 model. My Xfinity plan gets me 1G speed, which the old modem did not do (only up to 400). A Netgear R6300 wireless router is co...
- Mar 16, 2023
I replaced the router with a Nighthawk Mesh router and all is well. I'm now getting the gigabit speed that I expected. Thanks all for your help.
Kitsap
Mar 13, 2023Master
From a technology standpoint, your R6300 (pre Nighthawk) is way long in the tooth and outdated by current cable internet throughput. Agree with FURRYe38 , time to look for some new router hardware compatible with your new modem and internet service.
FrankAngel
Although the Netgear support person said it should be compatible with the higher speeds, you're probably correct. Any suggestions for a replacement Netgear wireless router?
- FrankAngelMar 13, 2023Aspirant
Oops, just saw the router you're using.
- FURRYe38Mar 13, 2023Guru - Experienced User
Try a RAX30 or 50 series. If you home is bigger or larger, you might consider something MESH like a MK60, 70 or 80 series.
- FrankAngelMar 16, 2023Aspirant
- FURRYe38Mar 16, 2023Guru - Experienced User
Enjoy. 📡
