FrankAngel
Mar 13, 2023Aspirant
Slower Internet Speed with New CM2000 Cable Modem
I recently switched out an older Netgear CM600 Cable Modem for a CM2000 model. My Xfinity plan gets me 1G speed, which the old modem did not do (only up to 400). A Netgear R6300 wireless router is co...
- Mar 16, 2023
I replaced the router with a Nighthawk Mesh router and all is well. I'm now getting the gigabit speed that I expected. Thanks all for your help.
Mar 13, 2023Guru - Experienced User
Try a RAX30 or 50 series. If you home is bigger or larger, you might consider something MESH like a MK60, 70 or 80 series.
FrankAngel
Mar 16, 2023Aspirant
