rgrimjr41
Nov 01, 2024Aspirant
Sometimes rebooting the CM2050V causes downstream light to blink.
My signal levels are good. The cable company has been out three times in the last two weeks. They say they cannot find a problem. I pay for Gigabit extra 1.2g/40mbps. Signal levels are all good abd optimally set. However, when I reboot the modem a good bit of the time when I reboot it the downstream light keeps flashing. It never stops not matter how long I leave it flashing for. Comcrapper has me firmware version V2.01.03.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- rgrimjr41AspirantEvent Log
Clear Log Refresh Export
Time Priority Description
Fri Nov 01 09:17:18 2024 (Warning (5)) DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:17:16 2024 (Critical (3)) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:05:19 2024 (Notice (6)) CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:05:19 2024 (Critical (3)) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:05:12 2024 (Warning (5)) Dynamic Range Window violation
Fri Nov 01 09:05:12 2024 (Warning (5)) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:05:11 2024 (Warning (5)) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:05:06 2024 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:05:01 2024 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6
Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:02:22 2024 (Notice (6)) CM-STATUS message sent. Event Type Code: 1; Chan ID: 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:02:21 2024 (Warning (5)) MDD message timeout;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:02:18 2024 (Notice (6)) CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:02:08 2024 (Warning (5)) Dynamic Range Window violation
Fri Nov 01 09:02:08 2024 (Warning (5)) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:02:07 2024 (Warning (5)) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:02:01 2024 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Fri Nov 01 09:01:56 2024 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:39:54:58;CMTS-MAC=04:2a:e2:c6:b0:ee;CM-QOS=1.1;CM-VER=3.1;
Help CenterShow/Hide Help Center- FURRYe38Guru - Experienced User
Please post a copy and paste of the modems connection status...
