justinlevi
Jul 25, 2022Star
Spectrum Gigabit service - Netgear CM2000 & Orbi RBK853 Not getting Full 1 Gig Speed
I recently upgraded my Spectrum service to 1gig last month and I was getting the full service speed for a couple of weeks. My download speeds are now pinning at near 100mbps. I've spoken with the spe...
justinlevi
Jul 25, 2022Star
Directly connected to the modem, I get my full gigabit speeds.
Any idea why the router can't connect to the modem at full speed?
Jul 25, 2022Guru - Experienced User
Waht firmware is on the orbi?
Are you using parental controls/armor on the orbi?
Did you check your wan port statistics when the speeds are low?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
(its an article for nighthawk but should work for orbi)
- justinleviJul 25, 2022Star
Firmware Version
V4.6.3.16_2.0.51
I'm not using any parental controls. I do have armor enabled and have no idea how to disable it if there is that option.
Here are the port statistics that I'm seeing when the internet speeds are low- justinleviJul 25, 2022Star
Here is my latest speed test from the router admin screen
- plemansJul 25, 2022Guru - Experienced User
Don't use the built in speedtest. Try directly connecting a pc/laptop to the router and host it on there.
The built in test doesn't always pick a good server
