AndySS
Mar 07, 2019Tutor
Speed issues with C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router
hello everyone
need help with
C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router. I have a 3400SQFT house and am facing range issues on the first floor. I got this router since it said that it would be good for a huge house. I need guidance on what can i do to enhance speed. Should i buy something else or modify something in the router?
thank you
- DarrenMSr. NETGEAR Moderator
You could buy one of the mesh extenders or look into something like orbi to connect to the C7000 to get better across a larger area.
DarrenM
- Ramon77TutorI have the exact problem you're having and I'm sorry to say I recieved no help! I have the exact model you have and it's nothing you're doing wrong but it's the latest firmwire that's causing slow internet speed. I've been trying to figure out how to revert back to a previous firmwire but with no luck. The firmwire is causing all of this!
- AndySSTutorThank you..am not very pro when it comes to network—what does this firmware thing have to do? And can that be fixed?
- ZeroC00lLuminary
Problem is these router like my c7000 you cannot update the firmware, Your ISP has to. I to get speed issues with it.
I wish Netgear would test it or push a new one for our ISP's. This has been going on for awhile now.
