dag_dg's avatar
dag_dg
Follower
Jul 03, 2019
Speed test on CM600
If anybody in the community has a CM600 and a connection with speeds higher than 600 Mbps can you please post speed test results? I'm confident this modem can handle speeds approaching it's rated limit of 960 Mbps but so far I'm only reaching around 550 Mbps even when directly connected to the modem. All 24 downstream channels show healthy. My provider is going to run a fresh line to the house to eliminate the cable being a possible cause. Like I said I'm pretty confident this modem can handle much higher speeds, it'd just put me at ease to see the results of other owners who are getting closer to the rated limit.
  • plemans's avatar
    Which provider do you use?
    The cm600 is rated "up to 960mbps" but each provider has a certain speed they'll guarantee with it.
    Comcast enables 24x8 modems (most vendors 24x8 units are the same) for mostly 250/300 Mbps extreme service and 400 Mbps Extreme service. So if you're hitting 600mbps, I'd think you're doing quite well with the CM600. Most require docsis 3.1 to hit gigabit speeds.
  • FURRYe38's avatar
    The CM is rated for:
    WAN throughput: 960 Mbps
    24 downstream & 8 upstream channels
    However most ISPs usally require a DOCSIS 3.1 and 32x8 channels for 900Mpbs services.
    What speeds on the down are you paying for?
    Might take to your ISP to ensure the signal up to the modem is good and working to spec.
