dpwct
Feb 15, 2018Aspirant
SSID suddenly reset
For no apparent reason my c3700 lost all settings including my ssid and password, now it is reset to default ssid/password (on bottom of router) what could have caused this. How can I avoid this in...
DarrenM
Feb 21, 2018Sr. NETGEAR Moderator
Maybe a power flash caused it to happen . If it keeps happening I suggest contacting support.
DarrenM
dpwct
Feb 21, 2018Aspirant
I was not doing a flash upgrade - whAt else could cause that.
What’s the best way to get a hold of support post warranty ?
Also I’m switching from Cable to fiber soon can I still use my C 3700 is just a router and not a cable modem if so what would I need to change in the settings
- antinodeFeb 21, 2018Guru
> [...] can I still use my C 3700 is just a router and not a cable modem
With no Ethernet WAN/Internet port, I don't see how. You ought to be
able to use it as a wireless access point, however. A step-by-step for
a C6300 should be here:
https://community.netgear.com/t5/x/x/m-p/1463500
That's for a C6300, but the steps are about the same for any other
router (any make/model) which lacks a one-step WAP option, including a
C3700.
