synoptics
Oct 06, 2015Guide
Static Routes C3000
I'm trying to replace a WGR614v9 and a DOCSIS 2.0 modem with a C3000, but can't find where to add static routes. I have 2. I can't believe this "router" doesn't support static routes or a simple rout...
- Oct 14, 2015I sent the C3000 back and replaced it with a WNR3500Lv2 router and a CM400 cable modem. This combination works fine. The WNR3500Lv2 supports static routes and RIP. It would have been nice to have these 2 functions in a single device but that wasn't happening.
TheEther
Oct 06, 2015Guru
While many Netgear routers support static routes and RIP, unfortunately, it appears that the C3000 does not.
